Tissot Couturier Automatic Chronograph Watch T035627 A EmptySun Dec 27 2020, 15:54 by Robti
Tissot Couturier Automatic Chronograph Watch T035627 A EmptySun Jun 21 2020, 12:11 by Robti
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyThu May 14 2020, 07:27 by Iceblue
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyWed Apr 01 2020, 15:35 by Robti
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyWed Jan 01 2020, 09:21 by Iceblue
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyTue Dec 31 2019, 20:41 by Iceblue
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyTue Dec 31 2019, 20:29 by Iceblue
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyWed Dec 25 2019, 21:47 by Robti
Tissot Couturier Automatic Chronograph Watch T035627 A EmptyWed Nov 13 2019, 17:54 by Iceblue
    Tissot Couturier Automatic Chronograph Watch T035627 A Empty Tissot Couturier Automatic Chronograph Watch T035627 A
    Post by domecurb Thu May 18 2017, 21:24
    its a big watch at 45mm wide and 18mm deep, but is very comfortable, i think the 24mm bracelet helps to support the weight, the dial is matt black and the indices and hands are bright polished steel, i was a bit concerned that there would be a lack of contrast between the dial and hands, but i think the matt finish helps with it as its very easy even in bright sun, as expected the fit and finish is excellent and it should be at the price point regardless of make.
    the movement is the Auto 28800 high beat ETA C01.211 and the chrono works faultlessly with a flyback centre chrono second hand, subdial at 9 is running seconds, dial at 12 is minutes up to 30 and the dial at 6 is hours up to 6.
    one of my favourite parts is the date window at 3, i think its the best date window and date disc i have seen, it even matches the dial colour exactly which is not common, all spied through a sapphire crystal.
    [You must be registered and logged in to see this image.]
    Tissot Couturier Automatic Chronograph Watch T035627 A Empty Re: Tissot Couturier Automatic Chronograph Watch T035627 A
    Post by SeikoJohn Thu May 18 2017, 21:31
    domecurb wrote:the movement is the Auto 28800 high beat ETA C01.211
    If it only had 800 beats less it could have become the Forums mascot watch Very Happy
    The matt dial with white detailing looks great against the polished steel hands . I know Tissot can be good watches and it certainly looks as though this one if definitely up there as one of the better ones.
    Certainly a good purchase well done Tissot Couturier Automatic Chronograph Watch T035627 A 3377044411
      Current date/time is Sat Apr 27 2024, 02:48
