Help pick a strap for my conquest EmptyYesterday at 10:55 by SeikoJohn
Help pick a strap for my conquest EmptyMon May 20 2019, 12:14 by domecurb
Help pick a strap for my conquest EmptySat May 18 2019, 09:01 by SeikoJohn
Help pick a strap for my conquest EmptyFri May 17 2019, 13:11 by domecurb
Help pick a strap for my conquest EmptyThu May 16 2019, 08:44 by daff62
Help pick a strap for my conquest EmptyWed May 15 2019, 10:57 by SeikoJohn
Help pick a strap for my conquest EmptyTue May 14 2019, 22:42 by domecurb
» Monday 13 May 2019.
Help pick a strap for my conquest EmptyMon May 13 2019, 08:51 by daff62
» Sunday 12 May 2019.
Help pick a strap for my conquest EmptySun May 12 2019, 12:07 by domecurb
Help pick a strap for my conquest Empty Help pick a strap for my conquest
Post by Robti on Fri Jun 09 2017, 11:47
Hi there doesn't seem to be a strap section so I posted here as its to do with my longines conquest, so I bought the watch and discovered that the strap is too short so I am looking for a dark brown with cream stitching croc/ gator with deployment, unless I can reuse the longines deployment.
So any pointers on where to buy ?
Thanks
Help pick a strap for my conquest Empty Re: Help pick a strap for my conquest
Post by domecurb on Fri Jun 09 2017, 13:04
[You must be registered and logged in to see this link.] wrote:Hi there doesn't seem to be a strap section so I posted here as its to do with my longines conquest, so I bought the watch and discovered that the strap is too short so I am looking for a dark brown with cream stitching croc/ gator with deployment, unless I can reuse the longines deployment.
Thanks
ebay has to be the answer, do a search for extra long in the size and style you want and there are thousands
i found this with a quick look:
[You must be registered and logged in to see this image.]
if you get the right dimensions IE the correct width where the strap fixes to the deployment then there is no reason why the deployment wont fit, a lot of straps do taper from the lug width down to the buckles so that is something to watch.
personaly i would avoid the big names like Hirsh etc as i really dont see how a little watch strap can be worth £50 or £60  or more Shocked   its just a little bit of [ usualy ] waste leather Wink  hope that helps a little
Post by Robti on Fri Jun 09 2017, 13:15
Thanks I have found loads on the bay but I couldn't tell if they were any good so that's why the post, thanks for the info on swapping the clasp.
Trots off to do some measuring
Post by domecurb on Fri Jun 09 2017, 13:46
[You must be registered and logged in to see this link.] wrote:Thanks I have found loads on the bay but I couldn't tell if they were any good so that's why the post, thanks for the info on swapping the clasp.
i think if you are after genuine aligator or croc then they will be expensive, but maybe i am not the one to advise as although i have plenty of watches on leather i dont wear leather straps, i have bought some very good straps off ebay though
    Current date/time is Wed May 22 2019, 03:52
